Hello. My wSher is draing the water right after it completes filling cycle. It does not begin agitate like its supposed to. Even if we manually place dial in agitate after it completes filling, it will drain water via drain pump action no matter what. When its draining the water, all light indicators are off. So its as though upon.filling, it shuts off and drains. The washer does not always do this. There are times that it washes just fine as it goes thru cycles normally. Any ideas, suggestions, greatly appreciated, please. thank you.
Your model number does not come up as a valid model, but even so it sounds like the control unit is bad. Try changing it out and see if that fixes things.
