IE error shown in display. We have checked clogged valves, kinked hose,s water pressure, etc, and everything is fine except tha the main wash valve is not letting water in due to voltage supplied (appox. 82 volts), so we have replaced the main board part # EBR36197323. After running QC test everything went ok, main inlet valve working, but after a few cycles we got same IE error, the main wash valve does not pass the QC test, and now the machine turn on by itself also. It starts filling with water, it seems the board is sending some voltage to the inlet valves no matter the machine is off. If we unplug from outlet the water stops entering into the drum, so the culprit seems not to be the valve itself. Any help would be appreciated
