My washer will sometimes not spin after a load of laundry, I have to drain and spin it for the laundry to get dry enough to put in the dryer. So I ran the diagnostic mode and received error codes F7E1 Basket Speed Sensor Fault and F7E7 Motor unable to reach target RPM. Then following the tech manual I ran manual test mode, low spin, high spin, gentle agitation and heavy agitation. All ran fine. So now what should I go ahead and take the machine apart to do the rest of the trouble shooting?
thanks Zaheer
