3 year old maytag front load washer model # MHWE200XW00 is out of warranty. I have excellent water supply going into the unit. The unit seems to work at till the last cicle and the drum will not spin to drain the water and displays an error code F7 and F1. Is this a water level pressure switch issue or could such a unit have greater issues? Thanks, Juan Rumino.
