Discuss
Whirlpool washer won't agitate
 in
Washer Repair
Hello, my Whirlpool washer fills with water and then won't agitate. It makes a low humming noise and you can
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Whirlpool washer won't agitate
  By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 06-11-2015, 01:26 PM
Junior Member
jmorgan5041 is on a distinguished road
Default Whirlpool washer won't agitate
Model Number: LSQ9549PG2   Brand: Whirlpool   Age: 5 - 10 years
Hello, my Whirlpool washer fills with water and then won't agitate. It makes a low humming noise and you can smell a slight electric burning smell. When I advance to control knob, it DOES pump out and spin. Any help would be greatly appreciated.
Related Models
Whirlpool LSQ9549PG2 AUTOMATIC WASHER
Whirlpool LSQ9549PG3 AUTOMATIC WASHER
Whirlpool LSQ9549PG5 AUTOMATIC WASHER
Whirlpool LSQ9549PG6 AUTOMATIC WASHER
Whirlpool LSQ9549PW0 AUTOMATIC WASHER
Whirlpool LSQ9549PW1 AUTOMATIC WASHER
Whirlpool LSQ9549PW2 AUTOMATIC WASHER
Whirlpool LSQ9549PW3 AUTOMATIC WASHER
Whirlpool LSQ9549PW5 AUTOMATIC WASHER
Whirlpool LSQ9549PW6 AUTOMATIC WASHER
Whirlpool LSQ9550PW0 AUTOMATIC WASHER
Whirlpool LSQ9550PW1 AUTOMATIC WASHER
Whirlpool LSQ9550PW2 AUTOMATIC WASHER
Whirlpool LSQ9550PW3 AUTOMATIC WASHER
Whirlpool LSQ9550PW4 AUTOMATIC WASHER
Whirlpool LSQ9560PW0 AUTOMATIC WASHER
Whirlpool LSQ9560PW1 AUTOMATIC WASHER
Whirlpool LSQ9560PW2 Residential Washer
Whirlpool LSQ9560PW3 AUTOMATIC WASHER
Whirlpool LSQ9560PW4 AUTOMATIC WASHER
Whirlpool LSQ9564JQ0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9564JQ1 WASHER - DIRECT DRIVE
Whirlpool LSQ9564JT0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9564JT1 WASHER - DIRECT DRIVE
Whirlpool LSQ9564JZ0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9564MQ0 AUTOMATIC WASHER
Whirlpool LSQ9565MQ0 WASHER
Whirlpool LSQ9600JQ0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9600JQ1 WASHER - DIRECT DRIVE
Whirlpool LSQ9600JT0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9600JT1 WASHER - DIRECT DRIVE
Whirlpool LSQ9600LG0 WASHER - DIRECT DRIVE
Whirlpool LSQ9600LG1 AUTOMATIC WASHER
Whirlpool LSQ9600LW0 WASHER - DIRECT DRIVE
Whirlpool LSQ9600LW1 AUTOMATIC WASHER
Whirlpool LSQ9610JQ0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9610JQ1 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9610JT0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9610JT1 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9610LG0 AUTOMATIC WASHER
Whirlpool LSQ9610LW0 AUTOMATIC WASHER
Whirlpool LSQ9620LG0 WASHER - DIRECT DRIVE
Whirlpool LSQ9620LG1 AUTOMATIC WASHER
Whirlpool LSQ9620LW0 WASHER - DIRECT DRIVE
Whirlpool LSQ9620LW1 AUTOMATIC WASHER
Whirlpool LSQ9645KQ0 WASHER
Whirlpool LSQ9645KQ1 WASHER
Whirlpool LSQ9645KT0 WASHER
Whirlpool LSQ9645KT1 WASHER
Whirlpool LSQ9650PG0 AUTOMATIC WASHER
Whirlpool LSQ9650PG1 AUTOMATIC WASHER
Whirlpool LSQ9650PG2 AUTOMATIC WASHER
Whirlpool LSQ9650PG3 AUTOMATIC WASHER
Whirlpool LSQ9650PG4 AUTOMATIC WASHER
Whirlpool LSQ9650PW0 AUTOMATIC WASHER
Whirlpool LSQ9650PW1 AUTOMATIC WASHER
Whirlpool LSQ9650PW2 AUTOMATIC WASHER
Whirlpool LSQ9650PW3 AUTOMATIC WASHER
Whirlpool LSQ9650PW4 AUTOMATIC WASHER
Whirlpool LSQ9659LG0 WASHER - DIRECT DRIVE
Whirlpool LSQ9659LG1 AUTOMATIC WASHER
Whirlpool LSQ9659LW0 WASHER - DIRECT DRIVE
Whirlpool LSQ9659LW1 AUTOMATIC WASHER
Whirlpool LSQ9659PG0 AUTOMATIC WASHER
Whirlpool LSQ9659PG1 AUTOMATIC WASHER
Whirlpool LSQ9659PG2 AUTOMATIC WASHER
Whirlpool LSQ9659PG3 AUTOMATIC WASHER
Whirlpool LSQ9659PG4 AUTOMATIC WASHER
Whirlpool LSQ9659PW0 AUTOMATIC WASHER
Whirlpool LSQ9659PW1 AUTOMATIC WASHER
Whirlpool LSQ9659PW2 AUTOMATIC WASHER
Whirlpool LSQ9659PW3 AUTOMATIC WASHER
Whirlpool LSQ9659PW4 AUTOMATIC WASHER
Whirlpool LSQ9660PG0 AUTOMATIC WASHER
Whirlpool LSQ9660PG1 AUTOMATIC WASHER
Whirlpool LSQ9660PG2 AUTOMATIC WASHER
Whirlpool LSQ9660PG3 AUTOMATIC WASHER
Whirlpool LSQ9660PG4 AUTOMATIC WASHER
Whirlpool LSQ9660PW0 AUTOMATIC WASHER
Whirlpool LSQ9660PW1 AUTOMATIC WASHER
Whirlpool LSQ9660PW2 AUTOMATIC WASHER
Whirlpool LSQ9660PW3 AUTOMATIC WASHER
Whirlpool LSQ9660PW4 AUTOMATIC WASHER
Whirlpool LSQ9665JQ0 WASHER
Whirlpool LSQ9665JQ1 WASHER
Whirlpool LSQ9665JQ2 WASHER
Whirlpool LSQ9665JQ3 WASHER
Whirlpool LSQ9665JQ4 WASHER
Whirlpool LSQ9665JT0 WASHER
Whirlpool LSQ9665JT1 WASHER
Whirlpool LSQ9665JT2 WASHER
Whirlpool LSQ9665JT3 WASHER
Whirlpool LSQ9665JT4 WASHER
Whirlpool LSR4100HQ0 AUTOMATIC WASHER
Whirlpool LSR4311DQ0 WASHER
Whirlpool LSR5100HQ0 AUTOMATIC WASHER
Whirlpool LSR5100KQ0 RESIDENTIAL WASHER
Whirlpool LSR5100LQ0 WASHER - DIRECT DRIVE
Whirlpool LSR5101LQ0 WASHER - DIRECT DRIVE
Whirlpool LSR5101LQ1 AUTOMATIC WASHER
Whirlpool LSR5102LQ1 AUTOMATIC WASHER
Whirlpool LSR5121HQ0 AUTOMATIC WASHER
Whirlpool LSR5121JQ0 AUTOMATIC WASHER,
Whirlpool LSR5132AG0 DIRECT-DRIVE WASHER
Whirlpool LSR5132AN0 DIRECT-DRIVE WASHER
Whirlpool LSR5132AW0 DIRECT-DRIVE WASHER
Whirlpool LSR5132HQ0 AUTOMATIC WASHER
Whirlpool LSR5132HQ1 AUTOMATIC WASHER
Whirlpool LSR5132JQ0 COMPACT WASHER
Whirlpool LSR5132JQ1 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSR5132JQ2 WASHER - DIRECT DRIVE
Whirlpool LSR5132PQ0 AUTOMATIC WASHER
Whirlpool LSR5132PQ1 AUTOMATIC WASHER
Whirlpool LSR5132PQ3 AUTOMATIC WASHER
Whirlpool LSR5132PQ4 AUTOMATIC WASHER
Whirlpool LSR5232DW0 AUTOMATIC WASHER
Whirlpool LSR5232LQ0 WASHER - DIRECT DRIVE
Whirlpool LSR5232LQ1 AUTOMATIC WASHER
Whirlpool LSR5233AG0
Whirlpool LSR5233AN0
  #2 (permalink)
Old 06-11-2015, 03:35 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
First, please, check if the cycle speed settings are correct, try different setting. Then unplug and disassemble the washer. Take the drain pump off and see if that make a difference (be careful to not get electrocuted). If no difference disconnect the motor from the transmission and try it again. If the motor start working, you have a bad transmission, if not - ether bad motor, timer or harness between them.
Here is the timer Part number: AP3738284
Click on the link for the disassembling instructions.
The motor Part number: AP2907974
The drain pump Part number: AP2907492
Here is the breakdown diagrams and parts list for your washer
Model LSQ9549PG2
Thank you.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 06-15-2015, 08:14 PM
Junior Member
Default
Thank you for the reply Simon.
So, I disassembled the washer (control panel, body off of frame) and removed the pump. I then plugged it in and put the control to agitate and it started agitating. I then put the pump back on, tried it again and it still agitated. I put the washer back together and everything seems fine, but now I am not sure why it was not agitating in the first place.
The issue in the first place was that it would not agitate, but it would pump out and spin. Oh well, I gave it a good cleaning while it was apart anyways. I guess time will tell if something is going bad.
  #4 (permalink)
Old 06-15-2015, 08:23 PM
Expert
Default
Hi.
I don't have a solid suggestion in your case, but I have a filling it could be a motor. It may happen again tomorrow or in six month. So...enjoy you washer
Thanks.
Simon.
__________________
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool washer won't agitate sparkync Washer Repair 0 02-06-2015 05:29 AM
Whirlpool Washer Won't Agitate mjlackey Washer Repair 3 08-22-2012 12:57 PM
Whirlpool Washer won't agitate. davez Washer Repair 3 04-20-2009 03:39 PM
Whirlpool Washer won't agitate rick cloud Washer Repair 0 03-31-2009 11:57 AM
Whirlpool Washer Won't Agitate jenn11 Washer Repair 9 01-21-2008 02:43 AM
