Washer works on every cycle but I haft to manually turn the switch. It will wash forever but won't go to next cycle without me doing this.
I think replacing the timer, this part here Part number: AP4024867
will fix things. It is expensive so you may want to replace the machine. But if you buy the part from this site and it does not fix the problem you can return it.
