When the Control knob on the front if the machine is turned to different settings the light associated with each setting will not move sometimes. Though at other times when the knob is moved only slightly the light will jump 3-4 settings. In other words trying to get the proper setting can sometimes take several tries and it is getting to the point where we will just use with the cycle that decides to show up when the light finally stops on a setting. It's sort of like playing roulette. You just never know where it's going to stop
