I have an LG washer that making a scraping sound during spin. I took off the rear access panel and lid. There is no water leaking and no rust in the bearing area. Everything looks almost new inside. Could this still be a bearing or maybe just the spider arm?
The washer is level but another thing I noticed was when I took off the access panel and looking from the top down into the machine, the drum looks like its at an angle, lower in the back than it is in the front. Is this the was it's suppose to be?
