jose silva
#1 Posted : Saturday, May 30, 2015 12:05:01 PM(UTC)
jose silva
I HAVE A FRONT LOAD FTF2140es3 when I turn it on it works for 3 seconds and seats for A MINUT RESTART FOR 3 second stops HELP!!!!!
I replaced the top control board, door locker is good, pressure switch,is good, drain pump is good, what else can I do,,PLEASE HELP ME THANK YOU
sidfink43
#2 Posted : Sunday, May 31, 2015 5:17:04 PM(UTC)
sidfink43
Well darn, that should have fixed it. Use the tech notes inside the lower panel to test the motor/speed control board. But first check all of the wiring and make certain the door lock wiring is okay.
sidfink43
#3 Posted: : Sunday, May 31, 2015 5:18:32 PM(UTC)
sidfink43
Well darn, what you did should have fixed it. Use the tech notes inside the lower service panel to test the motor/speed control board. And make sure the wiring to and from the door lock assembly is good and the connections are tight.
Frigidaire fgus2642lf2 auger not getting power (Refrigerator & Freezer Repair)
by knmens 4/15/2024 6:17:43 PM(UTC)
Frigidaire Evaporator Fan (Refrigerator & Freezer Repair)
by KevN1974 4/13/2024 11:03:34 AM(UTC)
Frigidaire gas dryer runs but no heat (Dryer Repair)
by Guest 3/16/2024 11:27:14 AM(UTC)
Frigidaire Freezer FPFU19F8WF4 - ice maker problem (Refrigerator & Freezer Repair)
by Eric8888 3/5/2024 11:02:19 AM(UTC)
Frigidaire Front Load Dryer aeq6000es2 (Dryer Repair)
by Guest 3/3/2024 7:28:15 AM(UTC)
Frigidaire FGHS2655PF5A Gallery side by side (Refrigerator & Freezer Repair)
by Rube 2/27/2024 7:56:33 PM(UTC)
Frigidaire Affinity Washing Machine - Leaking only sometimes (Washer Repair)
by omf_24 2/24/2024 4:45:41 PM(UTC)
Frigidaire dishwasher 2nd water inlet valve fails (Dishwasher Repair)
by Guest 2/13/2024 3:32:15 AM(UTC)
Frigidaire Front Load Washer only spins fast (Washer Repair)
by Guest 2/6/2024 12:15:55 PM(UTC)
Frigidaire oven diagram control board (Oven Repair (including Ranges and Cooktops))
by Guest 1/22/2024 10:28:10 AM(UTC)
Frigidaire Freezer Handle (Refrigerator & Freezer Repair)
by Guest 1/21/2024 12:46:23 PM(UTC)
Frigidaire Refrigerator model 253.56602402 issue (Refrigerator & Freezer Repair)
by anitak4242 1/17/2024 8:32:53 PM(UTC)
Frigidaire FSG747GES0 dryer motor (P/N 131461900) growls on start (Dryer Repair)
by RJ539 1/12/2024 9:00:21 AM(UTC)
Frigidaire upright freezer to warm (Refrigerator & Freezer Repair)
by jrklund311 1/11/2024 2:51:18 PM(UTC)
Frigidaire Gallery Refrigerator GRFS2853AF4 - Freezer not working (Refrigerator & Freezer Repair)
by Repaircat 1/9/2024 8:08:53 AM(UTC)
