Discuss
Maytag washer timer replacement
 in
Washer Repair
To remove the timer switch and dial plate. Pull the knob cover and rubber grip ring. To remove the knob
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Maytag washer timer replacement
  #1 (permalink)
Old 10-28-2009, 12:26 PM
Junior Member
edgurr is on a distinguished road
Wink Maytag washer timer replacement
Model Number: PAV3300   Brand: Maytag   Age: 5 - 10 years
To remove the timer switch and dial plate. Pull the knob cover and rubber grip ring. To remove the knob and dial plate, remove the white plastic rod from the back of the timer. The rod has a half-circle base and it will turn as you turn the knob. To remove the rod, pust the knob in so the rod base is nearly flush with the back of the timer. Using very fine needle nose pliers, pull the rod straight out.
After the rod is out, you can press the ears together holding the knob on.
To remove the switch assembly, remove the screw on the back of the timer. Lift the tab above where the screw way and slide the switch to the right.
Related Models
Admiral PAV3300AGW WASHER-TOP LOADING
Admiral PAV3300AKW WASHER-TOP LOADING
Maytag PAV3300AWW WASHER-TOP LOADING
Maytag PAV3360AWW WASHER-TOP LOADING
Admiral PAV3855AAW WASHER-TOP LOADING
Maytag PAV4960AWW WASHER-TOP LOADING
Maytag PAV5000AWQ WASHER-TOP LOADING
Maytag PAV5000AWW WASHER-TOP LOADING
Maytag PAV5057AWW WASHER-TOP LOADING
Maytag PAV5058AWW WASHER-TOP LOADING
Maytag PAV5157AWW WASHER-TOP LOADING
Maytag PAV5158AWW WASHER-TOP LOADING
Admiral PAVS234AWW WASHER-TOP LOADING
Admiral PAVS244AWW WASHER-TOP LOADING
Maytag PAVT134AWW WASHER-TOP LOADING
Maytag PAVT144AWW WASHER-TOP LOADING
Maytag PAVT234AWQ WASHER-TOP LOADING
Maytag PAVT234AWW WASHER-TOP LOADING
Maytag PAVT244AWQ WASHER-TOP LOADING
Maytag PAVT244AWW WASHER-TOP LOADING
Maytag PAVT344AWW WASHER-TOP LOADING
Maytag PAVT444AWW WASHER-TOP LOADING
Maytag PAVT454EWW WASHER-TOP LOADING
Maytag PAVT910AWW WASHER-TOP LOADING
Maytag PAVT915AWW WASHER-TOP LOADING
Maytag PAVT920AWW WASHER-TOP LOADING
Thermador PB30YS
General Electric PB750DN1BB ELECTRIC RANGE
General Electric PB750TN1WW ELECTRIC RANGE
General Electric PB900DP1BB ELECTRIC RANGE
General Electric PB900DP2BB ELECTRIC RANGE
General Electric PB900DP3BB ELECTRIC RANGE
General Electric PB900DP4BB ELECTRIC RANGE
General Electric PB900SP1SS ELECTRIC RANGE
General Electric PB900SP2SS ELECTRIC RANGE
General Electric PB900SP3SS ELECTRIC RANGE
General Electric PB900SP4SS ELECTRIC RANGE
General Electric PB900TP1WW ELECTRIC RANGE
General Electric PB900TP2WW ELECTRIC RANGE
General Electric PB900TP3WW ELECTRIC RANGE
General Electric PB900TP4WW ELECTRIC RANGE
General Electric PB909DP1BB ELECTRIC RANGE
General Electric PB909DP2BB ELECTRIC RANGE
General Electric PB909DP3BB ELECTRIC RANGE
General Electric PB909DP4BB ELECTRIC RANGE
General Electric PB909DP5BB ELECTRIC RANGE
General Electric PB909SP1SS ELECTRIC RANGE
General Electric PB909SP2SS ELECTRIC RANGE
General Electric PB909SP3SS ELECTRIC RANGE
General Electric PB909SP4SS ELECTRIC RANGE
General Electric PB909SP5SS ELECTRIC RANGE
General Electric PB909TP1WW ELECTRIC RANGE
General Electric PB909TP2WW ELECTRIC RANGE
General Electric PB909TP3WW ELECTRIC RANGE
General Electric PB909TP4WW ELECTRIC RANGE
General Electric PB909TP5WW ELECTRIC RANGE
General Electric PB909TR1CC ELECTRIC RANGE
General Electric PB909TR2CC ELECTRIC RANGE
General Electric PB910DP1BB ELECTRIC RANGE
General Electric PB910DP2BB ELECTRIC RANGE
General Electric PB910DP3BB ELECTRIC RANGE
General Electric PB910DP4BB ELECTRIC RANGE
General Electric PB910SP1SS ELECTRIC RANGE
General Electric PB910SP2SS ELECTRIC RANGE
General Electric PB910SP3SS ELECTRIC RANGE
General Electric PB910SP4SS ELECTRIC RANGE
General Electric PB910TP1CC ELECTRIC RANGE
General Electric PB910TP1WW ELECTRIC RANGE
General Electric PB910TP2CC ELECTRIC RANGE
General Electric PB910TP2WW ELECTRIC RANGE
General Electric PB910TP3CC ELECTRIC RANGE
General Electric PB910TP3WW ELECTRIC RANGE
General Electric PB910TP4CC ELECTRIC RANGE
General Electric PB910TP4WW ELECTRIC RANGE
General Electric PB920DP1BB ELECTRIC RANGE
General Electric PB920DP2BB ELECTRIC RANGE
General Electric PB920DP3BB ELECTRIC RANGE
General Electric PB920DP4BB ELECTRIC RANGE
General Electric PB920DP5BB ELECTRIC RANGE
General Electric PB920SP1SS ELECTRIC RANGE
General Electric PB920SP2SS ELECTRIC RANGE
General Electric PB920SP3SS ELECTRIC RANGE
General Electric PB920SP4SS ELECTRIC RANGE
General Electric PB920SP5SS ELECTRIC RANGE
General Electric PB920TP1WW ELECTRIC RANGE
General Electric PB920TP2WW ELECTRIC RANGE
General Electric PB920TP3WW ELECTRIC RANGE
General Electric PB920TP4WW ELECTRIC RANGE
General Electric PB920TP5WW ELECTRIC RANGE
General Electric PB969DP1BB ELECTRIC RANGE
General Electric PB969DP2BB ELECTRIC RANGE
General Electric PB969DP3BB ELECTRIC RANGE
General Electric PB969DP4BB ELECTRIC RANGE
General Electric PB969SP1SS ELECTRIC RANGE
General Electric PB969SP2SS ELECTRIC RANGE
General Electric PB969SP3SS ELECTRIC RANGE
General Electric PB969SP4SS ELECTRIC RANGE
General Electric PB970BM1BB ELECTRIC RANGE
General Electric PB970BM2BB ELECTRIC RANGE
General Electric PB970BM3BB ELECTRIC RANGE
General Electric PB970DP1BB ELECTRIC RANGE
General Electric PB970DP2BB ELECTRIC RANGE
General Electric PB970DP3BB ELECTRIC RANGE
General Electric PB970DP4BB ELECTRIC RANGE
General Electric PB970KM1CC ELECTRIC RANGE
General Electric PB970KM2CC ELECTRIC RANGE
General Electric PB970KM3CC ELECTRIC RANGE
General Electric PB970SM1SS ELECTRIC RANGE
General Electric PB970SM2SS ELECTRIC RANGE
General Electric PB970SM3SS ELECTRIC RANGE
General Electric PB970SM4SS ELECTRIC RANGE
General Electric PB970SP1SS ELECTRIC RANGE
General Electric PB970SP2SS ELECTRIC RANGE
General Electric PB970SP3SS ELECTRIC RANGE
General Electric PB970SP4SS ELECTRIC RANGE
General Electric PB970SP5SS ELECTRIC RANGE
General Electric PB970SP6SS ELECTRIC RANGE
General Electric PB970TM1WW ELECTRIC RANGE
General Electric PB970TM2WW ELECTRIC RANGE
General Electric PB970TM3WW ELECTRIC RANGE
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag dryer timer & harness replacement popi Dryer Repair 9 03-18-2010 07:21 PM
Timer and Knob Replacement For GE Top Load Washer cooltech Washer Repair 2 11-12-2009 06:05 PM
help how do you speciffically replace washer timer on Maytag washer stupid1 Washer Repair 5 07-04-2009 06:21 PM
maytag washer timer replacement how to stupid1 Washer Repair 0 07-03-2009 12:50 PM
Washer timer replacement. bpukas21 Washer Repair 2 10-31-2008 08:35 AM
