glendot
#1 Posted : Sunday, May 24, 2015 3:07:55 PM(UTC)
glendot
When I pull out on the control knob it does not engage. It just spins around. How do I get the knob off and possibly replace the control with a new one?
Glenn
sidfink43
#2 Posted : Tuesday, May 26, 2015 4:18:39 AM(UTC)
sidfink43
If you will post a model number someone should be able to help you. The problem may be the knob or it may be the timer itself.
GE Glasstop stove burner control knob (Oven Repair (including Ranges and Cooktops))
by Guest 9/17/2023 5:25:35 AM(UTC)
Where can I find a control knob to fit a 5mm D shaft potentiometer? (Dryer Repair)
by Guest 6/29/2022 11:20:48 AM(UTC)
Kenmore 970-C80032-00 dryer Control Knob (Dryer Repair)
by Guest 5/30/2022 8:16:19 AM(UTC)
change dacor oven from touch pad to manual control knobs (Oven Repair (including Ranges and Cooktops))
by prop 1/15/2019 11:04:14 AM(UTC)
how to remove washer control knob (Washer Repair)
by Mrs.fixit 7/30/2015 11:43:56 AM(UTC)
Dryer Control Knob Shaft (Dryer Repair)
by eogrady 12/28/2014 7:17:05 AM(UTC)
Range control knob broken (Oven Repair (including Ranges and Cooktops))
by boonjh 1/25/2014 3:16:45 PM(UTC)
Kitchenaid gas range power burner control knob doesn't turn past Lite (Oven Repair (including Ranges and Cooktops))
by dathinker 9/9/2013 9:31:18 AM(UTC)
Control Knob broke off during a move (Washer Repair)
by mattndi1991 8/4/2013 4:14:06 AM(UTC)
removing control knob on washer (Washer Repair)
by Jme1408 7/27/2013 8:51:53 PM(UTC)
Need Control Knobs (Oven Repair (including Ranges and Cooktops))
by ninaszlosberg 6/17/2013 4:13:45 PM(UTC)
Jenn-Air 5 burner control knobs are sparking (Oven Repair (including Ranges and Cooktops))
by HHStang 3/10/2013 6:55:34 PM(UTC)
Burner Control Knob (Oven Repair (including Ranges and Cooktops))
by Kdog12 7/17/2012 3:19:40 PM(UTC)
by kmenmart 7/16/2012 4:46:31 PM(UTC)
How do I remove sliding temp control knobs? (Refrigerator & Freezer Repair)
by Markzub 6/20/2012 6:32:24 PM(UTC)
