The motor stopped spinning with a 4 flash code. I ordered a new motor from GE, installed it and it worked 2 weeks before it stopped with a 7 flash code. I ordered another motor, the replacement lasted 1 day with another 7 flash code. I checked the lid switch and the lid fuse with a continuity check. What could be happening?
Hello Deedub. That is a error for a bad lid switch. You will need to replace the lid switch on the unit. Part number: AP3968471
