Washer will agitate, rinse, drain just fine but doesn't spin so clothes are still soaking wet at the end of a cycle. I Have replaced the clutch and motor/clutch are spinning at the right time. Lid switch checks out fine as well. I took out the inner tub and nothing was stuck inbetween inner and outer tub. The lower part of the outer tub was a little rusty but I dont think it is so bad as to keep it from spinning. Now, I'm at a loss, Any other ideas?
Maytag mtw5840two
Thanks!
