My Whirlpool Washer is flashing Code F6. What is my problem?
Thank You So Much!!! Brown Eyed Girl
Under the top or inside the lower service panel are tech notes that will tell you how to interpret the error codes and how to do some testing on the components that might be the problem.
In your case the error code means that the control unit is unable to detect that the tub is moving. This could be a wiring problem between the control unit and the motor control unit and the motor, or it could be a problem with the motor (unlikely) the motor control unit (likely) or the control unit. Use the tech notes to check all.
