| » Pressure Switch Hose p/n 3347780 Kenmore |
The hose is for the water level switch.
One end attaches to the outer tub or just goes into the outer tub. The other end attaches to the water level switch in the control console. Check that the hose does not have cracks or pinholes. If it does replace it. Also make sure it pushes snugly onto the level switch, if not cut off half an inch and try it. If this hose has an air leak the unit will overfill.
__________________
Thank you! I found it. I wasn't looking on the control panel at first, but found where the hose connects to. My next hold up is difficulty putting the washer housing (cover) back on. I see 2 slots in the bottom sides for the top sides to fit into but after 30 mins. I gave up until later. Any tips?
| Display Modes | |
| Pressure switch failure | walterwaterpolo | Washer Repair | 0 | 11-07-2009 07:11 AM |
| Pressure Switch Replacement | trnash9 | Washer Repair | 2 | 10-29-2009 11:18 AM |
| Kenmore HE2T Error F20 with tub overfill problem is pressure switch | jaj_wis | Washer Repair | 0 | 02-04-2009 12:31 PM |
| Water Does Not Stop/hose Disconnected To Pressure Switch | JANEY2008 | Washer Repair | 1 | 05-13-2008 05:53 AM |
| Injector hose leaks when water pressure is low | edpinarello | Washer Repair | 0 | 08-10-2007 11:13 PM |
