When I start the wash in any setting, the door clicks like it latched, then I hear this very faint click, like a switch or solenoid noise that's "trying" but not able to function, then the light switches to "no spin" and nothing happens. It started out doing the wash cycle but not spinning out, so I had to manually switch to the spin cycle every time. Also smelled a bit of what I thought may be the belt going. Now it just does what I mentioned above (nothing!!). I tried the diagnostic test and I came up with and error code of e23, I think. I hope it's not the board, but any part is expensive to replace! Thanks--Jen
