As the spin cycle starts, water comes back up the bleach dispenser and overflows the tub cover, thus running down the outside of the drum. Why?
It may be filling too high. Run it on medium and low level setting and see if the problem persists. And run it with the front panel off so you can see exactly what is happening.
Thank you for the reply. I did run it on medium and yes it does overflow less that way but still does overflow. I have run it with the front cover off, that is how I found out what was happening in the first place.
try replacing the water level switch, and make sure the tube between it and the tub is clear.
