Discuss
short deep metallic chirp noise
 in
Washer Repair
checked the agitator dogs while it was washing they were good. the noise seems to be associated with the tub
Appliance Repair Forum > Appliance Repair Help > Washer Repair » short deep metallic chirp noise
  #1 (permalink)
Old 04-09-2015, 06:43 PM
Junior Member
bgree is on a distinguished road
Default short deep metallic chirp noise
Model Number: 11021102012   Brand: Kenmore   Age: 1 - 5 years
the noise seems to be associated with the tub moving back and forth not
the agitator. hate to tear it down without a specific area to look at.
Bill
Related Models
Kenmore 11021112010 AUTOMATIC WASHER
Kenmore 11021112011 AUTOMATIC WASHER
Kenmore 11021182010 AUTOMATIC WASHER
Kenmore 11021182011 AUTOMATIC WASHER
Kenmore 11021202010 AUTOMATIC WASHER
Kenmore 11021202011 AUTOMATIC WASHER
Kenmore 11021252110 AUTOMATIC WASHER
Kenmore 11021292010 AUTOMATIC WASHER
Kenmore 11021292011 AUTOMATIC WASHER
Kenmore 11021302010 AUTOMATIC WASHER
Kenmore 11021302011 AUTOMATIC WASHER
Kenmore 11021352110 AUTOMATIC WASHER
Kenmore 11021392010 AUTOMATIC WASHER
Kenmore 11021392011 AUTOMATIC WASHER
Kenmore 11021392012 AUTOMATIC WASHER
Kenmore 11021882000 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021882001 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021884000 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021884001 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021892000 WASHER
Kenmore 11021894000 WASHER
Kenmore 11022032100 WASHER
Kenmore 11022032101 WASHER
Kenmore 11022032102 AUTOMATIC WASHER
Kenmore 11022036100 WASHER
Kenmore 11022036101 WASHER
Kenmore 11022036102 AUTOMATIC WASHER
Kenmore 11022042100 WASHER
Kenmore 11022042101 WASHER
Kenmore 11022042102 AUTOMATIC
Kenmore 11022052100 WASHER
Kenmore 11022052101 WASHER
Kenmore 11022052102 AUTOMATIC WASHER
Kenmore 11022054100 WASHER
Kenmore 11022054101 WASHER
Kenmore 11022054102 AUTOMATIC WASHER
Kenmore 11022056100 WASHER
Kenmore 11022056101 WASHER
Kenmore 11022056102 AUTOMATIC WASHER
Kenmore 11022062100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022062101 WASHER
Kenmore 11022062102 AUTOMATIC WASHER
Kenmore 11022064100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022064101 WASHER
Kenmore 11022064102 AUTOMATIC WASHER
Kenmore 11022066100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022066101 WASHER
Kenmore 11022066102 AUTOMATIC WASHER
Kenmore 11022082100 WASHER
Kenmore 11022082101 AUTOMATIC WASHER
Kenmore 11022082102 AUTOMATIC
Kenmore 11022084100 WASHER
Kenmore 11022084101 AUTOMATIC WASHER
Kenmore 11022084102 AUTOMATIC
Kenmore 11022086100 WASHER
Kenmore 11022086101 AUTOMATIC WASHER
Kenmore 11022086102 AUTOMATIC
Kenmore 11022292100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022294100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022422100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022432100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022442100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022622100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022632100 WASHER
Kenmore 11022642100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022652100 COMPACT WASHER
Kenmore 11022662100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022692100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022692101 AUTOMATIC WASHER
Kenmore 11022702100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022702101 AUTOMATIC WASHER
Kenmore 11022712100 WASHER
Kenmore 11022722100 WASHER
Kenmore 11022722101 WASHER
Kenmore 11022802100 WASHER
Kenmore 11022802101 AUTOMATIC WASHER
Kenmore 11022832100 WASHER
Kenmore 11022832101 AUTOMATIC WASHER
Kenmore 11022832102 AUTOMATIC WASHER
Kenmore 11022842100 WASHER
Kenmore 11022842101 AUTOMATIC WASHER
Kenmore 11022842102 AUTOMATIC WASHER
Kenmore 11022852100 WASHER
Kenmore 11022852101 AUTOMATIC WASHER
Kenmore 11022852102 AUTOMATIC WASHER
Kenmore 11022854100 WASHER
Kenmore 11022854101 AUTOMATIC WASHER
Kenmore 11022854102 AUTOMATIC WASHER
Kenmore 11022862100 WASHER
Kenmore 11022862101 AUTOMATIC WASHER
Kenmore 11022872100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022872101 AUTOMATIC WASHER
Kenmore 11022872102 AUTOMATIC WASHER
Kenmore 11022882100 WASHER
Kenmore 11022882101 AUTOMATIC WASHER
Kenmore 11022882102 AUTOMATIC WASHER
Kenmore 11022892100 WASHER
Kenmore 11022892101 AUTOMATIC WASHER
Kenmore 11022892102 AUTOMATIC WASHER
Kenmore 11022894100 WASHER
Kenmore 11022894101 AUTOMATIC WASHER
Kenmore 11022894102 AUTOMATIC WASHER
Kenmore 11022902100 WASHER
Kenmore 11022902101 AUTOMATIC WASHER
Kenmore 11022904100 WASHER
Kenmore 11022904101 AUTOMATIC WASHER
Kenmore 11022912100 WASHER
Kenmore 11022912101 AUTOMATIC WASHER
Kenmore 11022922100 WASHER
Kenmore 11022922101 AUTOMATIC WASHER
Kenmore 11022922102 AUTOMATIC WASHER
Kenmore 11022924100 WASHER
Kenmore 11022924101 AUTOMATIC WASHER
Kenmore 11022924102 AUTOMATIC WASHER
Kenmore 11022932100 WASHER
Kenmore 11022932101 AUTOMATIC WASHER
Kenmore 11022932102 AUTOMATIC WASHER
Kenmore 11022936100 WASHER
Kenmore 11022936101 AUTOMATIC WASHER
Kenmore 11022936102 AUTOMATIC WASHER
  #2 (permalink)
Old 04-10-2015, 04:35 PM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
It is almost impossible for us to diagnose a noise like that from afar. I suggest you take off the cabinet and jumper the lid switch and operate it and see if you can tell where the noise is coming from. It may be a problem with the pump, which runs continuously, or with the coupling or with the transmission, clutch or brakes. Check them all.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Deep Metallic Squawk bgree Washer Repair 0 03-14-2015 09:26 PM
Metallic noise in washer TRDCLNR95 Washer Repair 1 04-06-2013 09:12 PM
Dryer made short noise and stopped 88bonz Dryer Repair 1 02-01-2013 12:25 PM
starting to chirp iamtom Dryer Repair 1 08-16-2010 07:23 PM
deep noise while unit is running evrard102 Dishwasher Repair 1 12-04-2008 01:37 PM
