Discuss
Timer Or Lid Switch
 in
Washer Repair
Started Wash Cycle,washer Filled And Began To Agitate. After 20 Minutes I Noted A Electricial Burn Smell In The Air.
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Timer Or Lid Switch
  #1 (permalink)
Old 10-27-2009, 04:43 PM
Junior Member
MAINTENANCEMIKE is on a distinguished road
Default Timer Or Lid Switch
Model Number: LSN2000JQ0   Brand: Whirlpool   Age: 5 - 10 years
Started Wash Cycle,washer Filled And Began To Agitate. After 20 Minutes I Noted A Electricial Burn Smell In The Air. I Traced The Smell To My Washer, And Noted The Washer Was Still Washing At The Same Part Of The Cycle I Had Started. I Stopped The Cycle And Moved To The Rinse Setting And The Washer Drained And Filled And Agitated Again. I Watched It For 10 Min. And Again The Cycle Timer Did Not Move. I Also Noted That The Timer Was Not Emitting The Normal Ticking Tone It Once Had.
Is My Timer Bad Or Is There Another Relay In Sequence. What Is The Process For Testing And Elimination...?
Ads By Google
Related Models
Whirlpool LSN2000JQ0
Whirlpool LSN2000JQ1
Whirlpool LSN2000JQ2
Whirlpool LSN2000JT0
Whirlpool LSN2000JT1
Whirlpool LSN2000JT2
Whirlpool LSN2000LG0
Whirlpool LSN2000LG1 Automatic Washer
Whirlpool LSN2000LW0
Whirlpool LSN2000LW1 Automatic Washer
Whirlpool LSN2000PG0 Automatic Washer
Whirlpool LSN2000PG1 Automatic Washer
Whirlpool LSN2000PG2 Automatic Washer
Whirlpool LSN2000PG3 Automatic Washer
Whirlpool LSN2000PG4 Automatic Washer
Whirlpool LSN2000PW0 Automatic Washer
Whirlpool LSN2000PW1 Automatic Washer
Whirlpool LSN2000PW2 Automatic Washer
Whirlpool LSN2000PW3 Automatic Washer
Whirlpool LSN2000PW4 Automatic Washer
Whirlpool LSN3000PG0 Automatic Washer
Whirlpool LSN3000PG1 Automatic Washer
Whirlpool LSN3000PG2 Automatic Washer
Whirlpool LSN3000PG3 Automatic Washer
Whirlpool LSN3000PG4 Automatic Washer
Whirlpool LSN3000PW0 Automatic Washer
Whirlpool LSN3000PW1 Automatic Washer
Whirlpool LSN3000PW2 Automatic Washer
Whirlpool LSN3000PW3 Automatic Washer
Whirlpool LSN3000PW4 Automatic Washer
Whirlpool LSN7233BN0
Whirlpool LSN7233BN1
Whirlpool LSN7233BQ0
Whirlpool LSN7233BQ1
Whirlpool LSN7233BW0
Whirlpool LSN7233BW1
Whirlpool LSN7233DQ0
Whirlpool LSN7233DW0
Whirlpool LSN8244AN0
Whirlpool LSN8244AQ0
Whirlpool LSN8244AW0
Whirlpool LSN8244BN0
Whirlpool LSN8244BQ0
Whirlpool LSN8244BW0
Whirlpool LSP6244AG0
Whirlpool LSP6244AN0
Whirlpool LSP6244AW0
Whirlpool LSP6244BG0
Whirlpool LSP6244BN0
Whirlpool LSP6244BW0
Whirlpool LSP8244BG0
Whirlpool LSP8244BG1
Whirlpool LSP8244BN0
Whirlpool LSP8244BN1
Whirlpool LSP8244BW0
Whirlpool LSP8244BW1
Whirlpool LSP8245AN0
Whirlpool LSP8245AW0
Whirlpool LSP8245BN0
Whirlpool LSP8245BW0
Whirlpool LSP9245BN0
Whirlpool LSP9245BN1
Whirlpool LSP9245BW0
Whirlpool LSP9245BW1
Whirlpool LSP9355AG0
Whirlpool LSP9355AN0
Whirlpool LSP9355AW0
Whirlpool LSP9355BN0
Whirlpool LSP9355BN1
Whirlpool LSP9355BW0
Whirlpool LSP9355BW1
Whirlpool LSQ7030KQ0
Whirlpool LSQ7030LQ0
Whirlpool LSQ7030LT0
Whirlpool LSQ7030MQ0 Automatic Washer
Whirlpool LSQ7533JQ0
Whirlpool LSQ7533JQ1
Whirlpool LSQ7533JT0
Whirlpool LSQ7533JT1
Whirlpool LSQ8000HQ0
Whirlpool LSQ8000JQ0
Whirlpool LSQ8000JQ1
Whirlpool LSQ8000LQ0
Whirlpool LSQ8000LQ1 Automatic Washer
Whirlpool LSQ8000LQ2 Automatic Washer
Whirlpool LSQ8000LQ3 Automatic Washer
Whirlpool LSQ8200HQ0
Whirlpool LSQ8200HZ0
Whirlpool LSQ8220HQ0
Whirlpool LSQ8243HQ0
Whirlpool LSQ8243HZ0
Whirlpool LSQ8500JQ0
Whirlpool LSQ8500JQ1
Whirlpool LSQ8500JQ2
Whirlpool LSQ8500JT0
Whirlpool LSQ8500JT1
Whirlpool LSQ8500JT2
Whirlpool LSQ8500LQ0 Automatic Washer
Whirlpool LSQ8510LQ0 Automatic Washer
Whirlpool LSQ8511KQ0
Whirlpool LSQ8511KT0
Whirlpool LSQ8512KQ0
Whirlpool LSQ8512KT0
Whirlpool LSQ8520JQ0
Whirlpool LSQ8520JQ1
Whirlpool LSQ8543JQ0
Whirlpool LSQ8543JQ1
Whirlpool LSQ8543JT0
Whirlpool LSQ8543JT1
Whirlpool LSQ8543JZ0
Whirlpool LSQ8543JZ1
Whirlpool LSQ9010KQ0
Whirlpool LSQ9010KT0
Whirlpool LSQ9010LG0
Whirlpool LSQ9010LG1 Automatic Washer
Whirlpool LSQ9010LG2 Automatic Washer
Whirlpool LSQ9010LG3 Automatic Washer
Whirlpool LSQ9010LQ0
Whirlpool LSQ9010LQ1 Automatic Washer
Whirlpool LSQ9010LQ2 Automatic Washer
  #2 (permalink)
Old 10-28-2009, 01:59 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
Hi Mike
The elimination process that gets you to the timer as the problem is the fact that your machine will agitate, drain and spin, so mechanically it is ok. This leaves the control mechanism as the likely problem, which in your case is the timer.
I would recommend replacing the timer and hopefully that will solve your problem.
Good luck.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
new timer switch adjustment exmarinesgt Washer Repair 3 07-16-2009 04:07 PM
timer switch David J Domin Washer Repair 0 11-18-2008 01:42 PM
Switch or timer rebel#3 General Talk 1 10-08-2008 10:01 PM
new timer switch markwalter98 Dryer Repair 0 09-19-2008 08:26 AM
Fussy timer switch pcgoodwin Dryer Repair 1 02-24-2008 11:42 AM
