I need to replace the bearing in the outer tub of my front loading Maytag washer, model number MFW9700SQ1. I do not want to replace the whole outer tub; just the bearing. Can someone provide me with the bearing part number?
Thanks in advance.
Unfortunately the bearing is not available as a separate part, and as you can see replacing the outer tub is prohibatively expensive. So thanks to Maytag/Whirlpool this machine is unrepairable in this case.
Sorry.
