I fixed my 22 year old Whirlpool washer leaking problems by replacing the centerpost seal, the pump, water inlet valve (no hot water for over 10 years), and coupler. I stupidly reversed the black and white timer connectors when reinstalling the control console. Nothing happened when it was turned on but now, with all hooked up properly it won't fill at the fill position. But it will fill, spin,and empty all at the same time. Did I fry the timer?
