Hello. Okay spin stopped. Adjitation is fine. Motor turns left stops and turns right for Adjitation. Water drains then....nothing....if i wait( note machine tipped back slightly so I can see..bottom servicable...) then motor will turn for maybe 3 seconds....belt is NOT grabbing..If i Shake machine tub will start to spin....i have ordered a belt...ouch pricey...my question is...once belt is replaced could there be a potencial secondary issue that would add to the no spin?....wifes friend called and said now no drain.....before drain time was satisfactory..yet i did not check the pump for obstructions at the time since the machine drained fine. any insite is appreciated ....i would rather attack this with more parts than i need...then to have to go back....happy wife happy life (:
not sure what trackbacks are?
