Discuss
Kenmore washer leaking at rinse cycle
 in
Washer Repair
During the rinse cycle about 1/4 to 1/2 cup of water leaks out the bottom (back, left) of machine. No
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore washer leaking at rinse cycle
  #1 (permalink)
Old 10-27-2009, 04:05 PM
Junior Member
zeprulz is on a distinguished road
Default Kenmore washer leaking at rinse cycle
Model Number: 110.24082200   Brand: Kenmore   Age: 5 - 10 years
During the rinse cycle about 1/4 to 1/2 cup of water leaks out the bottom (back, left) of machine. No problems during the wash cycle. I haven't really ripped it apart yet, but thought someone may have an idea of why it would leak just during "rinsing" cycle. And as I said, it doesnt just flood...just about 1/2 cup.
Any help would be appreciated.
Kevin
Related Models
Hoover 1100
Kenmore 110088732791 WASHER/DRYER LAUNDRY SYSTEM
Magic Chef 1100PAA RANGE- F/S STD GAS
Magic Chef 1100PAW RANGE- F/S STD GAS
Magic Chef 1100PAW-K RANGE- F/S STD GAS
Magic Chef 1100PAW-KL RANGE- F/S STD GAS
Magic Chef 1100PAW-L RANGE- F/S STD GAS
Magic Chef 1100PRA RANGE- F/S STD GAS
Magic Chef 1100PRA-K RANGE- F/S STD GAS
Magic Chef 1100PRW RANGE- F/S STD GAS
Magic Chef 1100PRW-K RANGE- F/S STD GAS
Kenmore 11010202000 COMPACT WASHER
Kenmore 11010202001 WASHER
Kenmore 11010502990 AUTOMATIC WASHER
Kenmore 11010502991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11010852990 AUTOMATIC WASHER
Kenmore 11010852991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012202100 WASHER
Kenmore 11012502100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012852100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11013202200 WASHER
Kenmore 11013212200 AUTOMATIC WASHER
Kenmore 11014102300 AUTOMATIC WASHER
Kenmore 11014112300 AUTOMATIC WASHER
Kenmore 11014202300 AUTOMATIC WASHER
Kenmore 11014212200 AUTOMATIC WASHER
Kenmore 11014222300 AUTOMATIC WASHER
Kenmore 11014502300 AUTOMATIC WASHER
Kenmore 11014852300 AUTOMATIC WASHER
Kenmore 11015732400 WASHER
Kenmore 11015842400 WASHER
Kenmore 11015852400 WASHER
Kenmore 11015862400 WASHER
Kenmore 11015864400 WASHER
Kenmore 11015942400 RESIDENTIAL WASHER
Kenmore 11015942401 RESIDENTIAL WASHER
Kenmore 11015944400 RESIDENTIAL WASHER
Kenmore 11015944401 RESIDENTIAL WASHER
Kenmore 11015952400 RESIDENTIAL WASHER
Kenmore 11015952401 RESIDENTIAL WASHER
Kenmore 11015954400 RESIDENTIAL WASHER
Kenmore 11015954401 RESIDENTIAL WASHER
Kenmore 11015962400 RESIDENTIAL WASHER
Kenmore 11015962401 RESIDENTIAL WASHER
Kenmore 11015964400 RESIDENTIAL WASHER
Kenmore 11015964401 RESIDENTIAL WASHER
Kenmore 11016101690 AUTOMATIC WASHER
Kenmore 11016101691 AUTOMATIC WASHER
Kenmore 11016102500 WASHER
Kenmore 11016102501 RESIDENTIAL WASHER
Kenmore 11016102502 RESIDENTIAL WASHER
Kenmore 11016202690 WASHER
Kenmore 11016202691 AUTOMATIC WASHER
Kenmore 11016212500 WASHER
Kenmore 11016212501 WASHER
Kenmore 11016212502 RESIDENTIAL WASHER
Kenmore 11016212503 RESIDENTIAL WASHER
Kenmore 11016502690 WASHER
Kenmore 11016502691 AUTOMATIC WASHER
Kenmore 11016502692 AUTOMATIC WASHER
Kenmore 11016502693 AUTOMATIC WASHER
Kenmore 11016502694 AUTOMATIC WASHER
Kenmore 11016512690 WASHER
Kenmore 11016512691 AUTOMATIC WASHER
Kenmore 11016512692 AUTOMATIC WASHER
Kenmore 11016602690 AUTOMATIC WASHER
Kenmore 11016602691 AUTOMATIC WASHER
Kenmore 11016602692 AUTOMATIC WASHER
Kenmore 11016602693 AUTOMATIC WASHER
Kenmore 11016611690 AUTOMATIC WASHER
Kenmore 11016611691 AUTOMATIC WASHER
Kenmore 11016611692 AUTOMATIC WASHER
Kenmore 11016612690 AUTOMATIC WASHER
Kenmore 11016612691 AUTOMATIC WASHER
Kenmore 11016612692 AUTOMATIC WASHER
Kenmore 11016732500 WASHER
Kenmore 11016812500 WASHER
Kenmore 11016812501 WASHER
Kenmore 11016812502 RESIDENTIAL WASHER
Kenmore 11016812503 RESIDENTIAL WASHER
Kenmore 11016852500 WASHER
Kenmore 11016852501 WASHER
Kenmore 11016852502 WASHER
Kenmore 11016852503 WASHER
Kenmore 11016862500 RESIDENTIAL WASHER
Kenmore 11016862501 WASHER
Kenmore 11016862502 WASHER
Kenmore 11016862503 RESIDENTIAL WASHER
Kenmore 11016872690 WASHER
Kenmore 11016872691 AUTOMATIC WASHER
Kenmore 11016872692 AUTOMATIC WASHER
Kenmore 11016872693 AUTOMATIC WASHER
Kenmore 11016882500 RESIDENTIAL WASHER
Kenmore 11016882501 WASHER
Kenmore 11016882502 WASHER
Kenmore 11016882503 RESIDENTIAL WASHER
Kenmore 11016922500 WASHER
Kenmore 11016922501 RESIDENTIAL WASHER
Kenmore 11016922502 WASHER
Kenmore 11016922503 WASHER
Kenmore 11016922504 RESIDENTIAL WASHER
Kenmore 11016942500 WASHER
Kenmore 11016942501 WASHER
Kenmore 11016942502 WASHER
Kenmore 11016942503 RESIDENTIAL WASHERS
Kenmore 11016962500 WASHER
Kenmore 11016962501 WASHER
Kenmore 11016962502 WASHER
Kenmore 11016962503 RESIDENTIAL WASHERS
Kenmore 11016964500 WASHER
Kenmore 11016964501 WASHER
Kenmore 11016964502 WASHER
Kenmore 11016964503 RESIDENTIAL WASHERS
Kenmore 11016972500 WASHER
Kenmore 11016982500 WASHER
Kenmore 11016984500 WASHER
Kenmore 11016986500 WASHER
Kenmore 11017102700 RESIDENTIAL WASHER
Kenmore 11017122700 RESIDENTIAL WASHER
Kenmore 11017132700 RESIDENTIAL WASHER
  #2 (permalink)
Old 10-28-2009, 01:56 PM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
I am guessing it is leaking during the wash cycle, but because it is a small leak you do not notice it until it has built up a little.
Either way the method to diagnose the leak is to open up the machine and watch it while it is leaking. If you do not already have it, here is a Calypso service manual which will show you how.
https://secured.whirlpool.com/Servic...LE/8178010.pdf
__________________
  #3 (permalink)
Old 10-30-2009, 10:09 AM
Junior Member
Default Wrong manual?
The instructions for raising the washer top don't apply to my model. I dont have an emblem on the front or a torx bolt. So I don't know how to get the top up in order to get the front panel off.
Is there another manual for my model?
Thanks,
KK
  #4 (permalink)
Old 10-30-2009, 11:28 AM
Junior Member
Default long clear plastic tubing
Well I found where the leak is coming from. There is a long plastic very thin "drain" tube that just hangs down from an outlet in the outer drum. When the rinsing cycle starts, water just comes out of there and just goes to the bottom panel and then out the bottom. Can't find this plastic tubing on diagrams, but that's where it's coming from.
Anymore help would be appreciated. Not sure why water comes out of there, but it sure seems like thats what it was made for, but the other end just hangs free.
Thanks,
Kevin
  #5 (permalink)
Old 10-30-2009, 12:15 PM
Senior Expert
APP Volunteer
Default
On some of these models you have two water pressure switches. They both operate by a hose that goes from the switch into the tub. When water enters the tub it increases air pressure in the hose, which in turn activates the switch to shut off the water at the correct level.
The operating pressure switch is the main one, but your model may have an overflow switch, which is set to shut off the water if it rises above the level that it should from the operating switch and the operating switch fails. As long as your operating switch is ok, the overflow switch does not come into play, so if the hose to it were disconnected it would not affect your operation.
The hose you see may be from the overload water pressure switch if you have one. Check and see if you have a switch labeled FLD without a hose coming to it. If so, connect up your drooping hose and you should be all set.
__________________
  #6 (permalink)
Old 10-30-2009, 12:40 PM
Junior Member
Default Not sure I understand....
This is not a rigid type rubber hose. It's more of a very thin plastic sleeve. I have attached pictures of both ends. One end is just hanging, the other end is up and attached to what looks like an elbow connector on the outer drum.
  #7 (permalink)
Old 10-30-2009, 01:31 PM
Senior Expert
APP Volunteer
Default
I did mis-understand your descripton, and thanks for the pictures, but now both of us are confused. I am not sure what that is or what it does, maybe another tech can help us out here.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer humms at rinse cycle won't rinse xirwinite Washer Repair 2 10-13-2009 08:33 PM
Washer goes to rinse cycle then spin back to rinse, stuck in this mod Pat66 Washer Repair 1 05-08-2009 07:44 AM
Washer will not go through rinse or spin cycle on regular cycle dhilde7165 Washer Repair 0 02-14-2009 04:10 PM
Washer fills on wash cycle and rinse cycle and won't stop filling! riphinney Washer Repair 15 03-12-2008 05:30 PM
Crosley Cw8000w Leaking on rinse cycle from bottom of the tub? roller2 Washer Repair 2 01-12-2008 09:10 AM
