My washing machine vibrates really bad when it spins out. i have adjusted the legs twice, have taking the face and top off and checked the springs and still haven't found anything wrong with it. I would really appreciate the help thanks.
Replace the springs. When they go it is almost impossible to tell from visual inspection. They are inexpensive, and new one will likely solve your problem. If it does not, it is good maintenace anyway so it is not a waste of funds. Look at the pads while you are in there.
Good luck, Let us know how it turns out.
I would look at the triangular skate board under the tub for missing, worn brown plastic pads.
