Machine make very loud squeaking sound when it first begins to agitate but then it works fine and finishes cycle. (clothes are a little damper than normal when finished though).
Noises like this are hard to diagnose without being there to hear them. Try operating it with the front panel off and see you can tell if where the noise is coming from. Sounds like the problem may be in the mode shifter.
