Mike Ragans
#1 Posted : Friday, March 27, 2015 2:47:26 PM(UTC)
Mike Ragans
Washer wont spin clutch, lid switch, drive tube and coupling are fine. Need help.
fairbank56
#2 Posted : Friday, March 27, 2015 4:16:55 PM(UTC)
fairbank56
Groups: Expert
Does it drain? Does the motor run when in spin mode? Does the clutch hub rotate while in spin mode?
Eric
Mike Ragans
#3 Posted : Friday, March 27, 2015 5:10:13 PM(UTC)
Mike Ragans
Eric
Eric, yes to all three. Clutch assembly installed new, motor runs fine, aggitates fine, coupler is new.
fairbank56
#4 Posted : Friday, March 27, 2015 6:36:40 PM(UTC)
fairbank56
Groups: Expert
So, while you are observing the clutch hub spinning, look up into the brake hub. Is the basket drive rotating? Bottom of basket drive consists of the brake shoes and brake spring. If they are rotating but basket is not, then your drive block is suspect. If basket drive is not spinning, then the clutch band is slipping or the brake cam driver is broken.
Eric
** LG Washer wont spin - LE Error ** WM4070HVA (Washer Repair)
by jborka 3/14/2024 6:15:24 PM(UTC)
Whirlpool LTE6234DQ2 Wont Spin (Washer Repair)
by kelgun 12/7/2023 2:53:34 PM(UTC)
my fully automatic washer,(top loader) WONT SPIN (Washer Repair)
by johnsail2000 4/14/2023 8:51:18 PM(UTC)
GE Washer wont spin at the high speed GHWN4250D0WW (Washer Repair)
by ssauer40 1/10/2022 4:19:44 AM(UTC)
washer wont spin (Washer Repair)
by allen9258 4/8/2018 11:08:33 PM(UTC)
GE top load wont spin (Washer Repair)
by NOELLE.EUAN 10/15/2017 5:03:37 PM(UTC)
Hotpoint wont spin or drain (Washer Repair)
by Snowostrich 7/1/2017 2:53:32 PM(UTC)
by malakye 3/5/2017 1:18:25 PM(UTC)
Maytag Bravos Washer wont spin (Washer Repair)
by utzzy27 10/2/2016 1:15:15 PM(UTC)
Kenmore wont spin or drain. no noise. Lid switch does click. (Washer Repair)
by DCAJR1 8/17/2016 12:09:50 PM(UTC)
Wont spin on *some* settings (Washer Repair)
by merkman 7/18/2016 7:15:38 PM(UTC)
washer wont spin out (Washer Repair)
by dokratt 4/16/2016 2:50:25 PM(UTC)
Maytage wont spin (Washer Repair)
by Mike055 12/10/2015 11:15:41 AM(UTC)
Maytag Neptune washer wont spin or cycle (Washer Repair)
by Tonya 44 11/17/2015 12:56:58 PM(UTC)
ge washer wont spin or agitate (Washer Repair)
by outback32 9/29/2015 9:46:08 AM(UTC)
