I have a Duet washer and it DOES NOT have a front access panel. I need to access the drain plug but can't get the front panel off. How do I remove this panel?
Have not worked on this model, haven't even seen one like it. Here is a diagram of the unit Parts for Whirlpool WFW95HEXL2 Washer - AppliancePartsPros.comand I would think that if you remove the top you can remove the front and get access that way. Also, talk to Whirlpool and see if they can provide you with a service manual for the unit.
