Pump belt broke as i retrieved it I noticed the floor was wet upon further inspection the seep hole on the pump felt wet. Also the seep hole itself has black pieces of plastic it looks like the came out when i touched the seep hole.Is this a sign of bad bearing? Or is that normal when a pump goes bad? Id hate to spend 60 to 70 dollars do the work and find out the bearing is bad or the shaft is bad...Is it worth fixing?/ Thanks
