Wash water (not rinse) is always warm. When "cold" is selected, the macine fills with warm water; when "hot" is selected, same problem. I checked the temperature of the water at the hose connection: 60 deg. Fahrenheit. Manual says 60 degrees is minimum for effective detergent usage. Is Automatic Temp. Control adding hot water to bring temp above 60? Why does it add cold when "hot" is set? Replace A.T.C.?
