Washer stopped spinning. Original diagnostic was E35 (communication problem) Replaced control board. Now error code E31 pressure switch. Ordered switch through appliance pros. Received today and still the same problem and error code (E31). Installed original control board and now it's a whole new error code. E41 (door lock assembly/switch).. I then proceeded to ohm out the door latch solenoid and the values were within range as noted on the schematic diagram..
Not sure what to do at this point.. Anyone??
