I have cleaned filters and changed hoses but still have no cold water pressure. What causes this???
Groups: Expert
Swap the electrical connections at the hot and cold water valve solenoids and then select cold water. If you get hot water, your valve assembly is faulty. If not, replace the temperature switch.
Eric
