All was well, worked great with no problems until we relocated the washer. Hooked it up and it filled. After it reached the designated level ZI heard a click in the area behind the dials, and then a hum in the same area. Turned the dial slowly and heard subsequent clicks and only the same hum. Lid switch makes the click noise when closed but no agitation or spin cycles. Pump and motor both turn freely. Any ideas??
