Loaded machine this morning, wash cycle started normally but when I came back a half hour later it wasn't working but hadn't finished the cycle. Clothes were sitting in water and nothing happening. Drum won't spin, thought it would be the belt so I removed back panel to check and replace belt if necessary. Belt is still tight and does not seem worn.
I set control to "Drain" and pressed start. It drained the water normally. I removed clothes and drained all the water through filter drain. I set control to "Spin" and pressed start. Water pump starts up but drum does not spin. The drum motor is not turning or vibrating nor is it hot.
Is there a fuse or a reset for the drum motor? Has me baffled.
