drop4/5
#1 Posted : Thursday, February 5, 2015 9:59:19 AM(UTC)
drop4/5
Stopped in the middle of the wash with wet clothes, pulled the pump and garbage out reconnected and still just fills and empties but no agitate or spin cycle. Appears to be the door switch but codes indicate main board. Anyway to tell for sure. Takes 3 times as long just to go through a cycle without washing the clothes.
Thanks for any help!
Ron
sidfink43
#2 Posted : Thursday, February 5, 2015 2:15:07 PM(UTC)
sidfink43
I think the bad board is the more likely correct diagnosis, so try and replace it and see if that fixes things. If you buy the board from this site and it does not fix the situation you can return it.
drop4/5
#3 Posted : Thursday, February 5, 2015 5:09:44 PM(UTC)
drop4/5
Thanks Sid, gotta guess you hit the nail on the head. Tried the door switch and no luck so I gotta wait for the board to come in.
Thanks Ron
sidfink43
#4 Posted : Thursday, February 5, 2015 5:39:06 PM(UTC)
sidfink43
Good luck, let us know how it turns out.
Frigidaire Affinity Washing Machine - Leaking only sometimes (Washer Repair)
by omf_24 2/24/2024 4:45:41 PM(UTC)
Washer leak Frigidaire Affinity (Washer Repair)
by Guest 10/23/2023 1:59:44 PM(UTC)
Control board for Frigidaire Affinity dryer (E68 error code) (Appliance Parts)
by VanFramez 12/18/2022 11:57:30 AM(UTC)
Frigidaire Affinity Dryer, seem stuck on high heat (Dryer Repair)
by GoldToyBox 4/29/2022 4:53:20 PM(UTC)
Frigidaire Affinity NO START, the light is not on when the door is open (Dryer Repair)
by Guest 3/13/2022 9:02:49 PM(UTC)
frigidaire affinity dryer LEQ6000es2 Stuck in mode (Dryer Repair)
by Guest 7/13/2021 5:25:53 AM(UTC)
Frigidaire Affinity Noise when filling (Washer Repair)
by PaganJim 4/3/2021 8:52:05 AM(UTC)
2011 Frigidaire Affinity Dryer (Dryer Repair)
by Donnchad 11/1/2020 3:01:12 PM(UTC)
Frigidaire affinity dryer model number fase7073a2 (Dishwasher Repair)
by Ann P 7/28/2020 7:31:25 PM(UTC)
Frigidaire Affinity Dryer AGQ6700FS2 (Dryer Repair)
by moh 7/8/2020 3:29:08 PM(UTC)
Frigidaire Affinity door sag (Washer Repair)
by KDub 4/3/2020 12:40:23 PM(UTC)
Frigidaire affinity no heat (Dryer Repair)
by humonculi 2/18/2020 2:00:03 PM(UTC)
Frigidaire affinity stops running, lights blinking, no heat (Dryer Repair)
by klindquist 10/17/2019 2:25:58 PM(UTC)
Frigidaire Affinity Washer not final spin (Washer Repair)
by Jcrosslin 10/16/2019 7:21:36 AM(UTC)
Frigidaire Affinity motor control board? (Washer Repair)
by acoonen 3/21/2019 1:16:40 PM(UTC)
