cuflipside9@aol.com
#1 Posted : Sunday, February 1, 2015 11:55:28 AM(UTC)
cuflipside9@aol.com
Machine had stopped working in the middle of a wash cycle. No power at all.
CCU needed to be repaired. I removed the front kick panel to be able to unlock the door(get cloths out) and found in the back was a green service manual with how-to fix certain codes and how to remove the CCU. It was very easy to remove once I read the manual. I labeled the wires so I new which ones went on top, side and other side. Easy to reconnect them as they only go in their slot and no others.
sidfink43
#2 Posted : Monday, February 2, 2015 2:15:07 PM(UTC)
sidfink43
Good job, and thanks for sharing the experience with everyone.
Whirlpool Duet Washer - Possible Faulty Fill Valve (Washer Repair)
by Guest 2/2/2024 4:18:21 PM(UTC)
Whirlpool duet washer not draining (Washer Repair)
by Guest 2/16/2022 8:40:23 AM(UTC)
Whirlpool Duet Washer - Wire broken off connector on harness (Washer Repair)
by Cephalon 1/21/2021 9:33:49 PM(UTC)
Whirlpool Duet Washer Codes (Washer Repair)
by mbocon 3/10/2020 5:04:51 PM(UTC)
Whirlpool duet washer (Dishwasher Repair)
by Julia Johnson 11/1/2017 9:53:41 AM(UTC)
What happened to my Whirlpool Duet washer?? (Washer Repair)
by colbran 10/2/2017 12:01:48 PM(UTC)
Whirlpool Duet Washer (Washer Repair)
by Bmbrouillette 7/2/2017 11:05:32 AM(UTC)
Whirlpool duet washer- won't start after replacing CCU and door latch (Washer Repair)
by Ivanick 5/22/2017 6:07:41 PM(UTC)
Whirlpool Duet washer FH code (Washer Repair)
by farmgirl 1/17/2017 7:14:25 PM(UTC)
whirlpool duet washer F06 E02 error (Washer Repair)
by tnafranklin 10/18/2016 12:47:55 PM(UTC)
whirlpool duet washer (Washer Repair)
by Oathose 4/4/2016 7:23:01 PM(UTC)
Whirlpool Duet Washer bellow tore in two. (Washer Repair)
by pitwoman 1/28/2016 5:42:42 PM(UTC)
by CrosbyFamilyFarm 12/31/2015 1:28:32 PM(UTC)
Whirlpool Duet Washer not working (Washer Repair)
by Shanej69 11/23/2015 1:59:18 PM(UTC)
Whirlpool Duet washer start button is broken (Washer Repair)
by bjgamble 9/7/2015 7:04:46 AM(UTC)
