my stackable maytag washer will not fill with water, it was working put in new water valves so had to move it put back in place and now nothing any ideas
Open it back up again and check to see if the timer is getting power and then check all of the connections. You may have knocked something loose during your earlier repair. (been there, done that myself). Finally, check to see that power is getting to the valve assembly when it calls for water and that water is on and unobstructed.
