spectre_
#1 Posted : Monday, January 19, 2015 5:24:12 PM(UTC)
spectre_
Hi ,
I have a Maytag Model # MAV8557AWW . The washer fills, drains, agitator moves, motor runs, belt looks fine. There was a high pitched noise during spin cycle that has stopped now, and the drum was spinning freely for a long time after spin cycle. Now no noise and wont spin. Water still drains just not spinning.The drum will not move by hand. Do you think it is the thrust bearing that is not allowing the drum to spin?
Thanks for any help. Sorry if I double post.
sidfink43
#2 Posted : Tuesday, January 20, 2015 4:25:09 PM(UTC)
sidfink43
If the water is draining then this means the motor is turning and the belt is driving the pump. So I would try replacing the thrust bearing. If the transmission or brakes were the problem the motor would be destroying the belt.
spectre_
#3 Posted : Thursday, January 22, 2015 11:44:30 AM(UTC)
spectre_
Thanks for the advice. I purchased a thrust bearing kit and a belt from parts pro. I'll find out soon. The lady that helped me was very knowledgeable . Parts arrived in 2 days.
sidfink43
#4 Posted : Thursday, January 22, 2015 12:03:28 PM(UTC)
sidfink43
Great, let us know how it turns out. Watch the video if you need help.
spectre_
#5 Posted : Thursday, January 29, 2015 3:16:49 PM(UTC)
spectre_
Just want to say thanks for the advice. Parts were easy to install . The clip was a little bit of a challenge . Half hour Max . Not bad for first time. Thanks again. :)
sidfink43
#6 Posted : Thursday, January 29, 2015 3:33:12 PM(UTC)
sidfink43
Great, glad you got it working and thanks for the update.
