I have a GE HydoWave washer that squeaks when in the wash mode. The tub does not fill like I think it should. It is less than 2 years old and has squeaked since it was new. It squeaks when in agitation but seems to squeak when the water level is low. If you put it on auto fill and it never seems to put much water in the tub and squeaks. Even when you put it on higher water levels it does not seem like the tub has much water in it. If it has very little cloths in it and the water level is higher it does not squeak.
Any suggestions? Jeff Howell
I would take off the front panel and see if there are any lights flashing on the motor. These are error codes. HydroWave GE Washer Repair GuideThe water level problem could be function of the water level switch. The noise is not something we can really diagnose; operate the machine with the front panel off and see if you determine its source and location.
