It first started with the washer not spinning so I did the test and fault code for" drive system shifter" so I repaced the shifter assembly & it worked for three days then stopped working again...Now I get code"drive system motor" & the washer spins but it doesn't go through the wash cycle correctly....I'm starting to think it's the "main control panel"..
Help please!!
