the agitator does not work on wash cycle but it does on spin cycle,what might be the problem?
I am not certain by what you mean when you say the agitator does not work on the wash cycle but does on the spin cycle. I would suggest you remove the front panel and observe the machine during its full cycle and see what is happening with the motor and transmission. This will help you determine where the problem is.
If you need more help please post the results of your observations and provide us with more detail as to what exactly is happening.
good luck.
