Discuss
Washer won't start water flow when hot water is selected.
 in
Washer Repair
The washer will not start water flow when hot water is selected. At times if I jiggle the timer/start knob
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer won't start water flow when hot water is selected.
  #1 (permalink)
Old 12-12-2014, 02:57 PM
Junior Member
Jeff Bast is on a distinguished road
Default Washer won't start water flow when hot water is selected.
Model Number: MV7557EWW   Brand: Maytag   Age: 5 - 10 years
The washer will not start water flow when hot water is selected. At times if I jiggle the timer/start knob just right the flow will begin. Works fine in cold and warm settings. It seems that the issue lies within the start knb/timer assembly. Can anyone tell me what the issue is and what part is the problem? Thanks!
Related Models
Amana MVH-1020 MWAVE- MOUNTED OVER RANGE/WO
Amana MVH-700 MWAVE- MOUNTED OVER RANGE/WO
Amana MVH-720 MWAVE- MOUNTED OVER RANGE/WO
Amana MVH-900 MWAVE- MOUNTED OVER RANGE/WO
Amana MVH-920 MWAVE- MOUNTED OVER RANGE/WO
Amana MVH-9T MWAVE - FAMILY SIZE (60 HZ)
Amana MVH-9T MWAVE- MOUNTED OVER RANGE/WO
Amana MVH100E1 MWAVE- MOUNTED OVER RANGE/WO
Amana MVH110E MWAVE- MOUNTED OVER RANGE/WO
Amana MVH110E1 MWAVE - FAMILY SIZE (60 HZ)
Frigidaire MVH1150C0 Frg(v0) / Microwave Oven
Frigidaire MVH1150C1 Frg(v0) / Microwave Oven
Frigidaire MVH1150C2 Frg(v1) / Microwave Oven
Frigidaire MVH1190A Frg(v1) / Microwave
Frigidaire MVH1190E1 Frg(v1) / Microwave
Frigidaire MVH1190E2 Frg(v1) / Microwave
Frigidaire MVH1190N Frg(v1) / Microwave Oven
Frigidaire MVH1190P Frg(v1) / Microwave
Frigidaire MVH1195A Frg(v1) / Microwave
Frigidaire MVH1199A Frg(v2) / Microwave
Frigidaire MVH1199N Frg(v2) / Microwave Oven
Frigidaire MVH1199P Frg(v2) / Microwave
Amana MVH120E MWAVE- MOUNTED OVER RANGE/WO
Amana MVH130E MWAVE - FAMILY SIZE (60 HZ)
Amana MVH130W MWAVE - FAMILY SIZE (60 HZ)
Amana MVH140E MWAVE- MOUNTED OVER RANGE/WO
Amana MVH140W MWAVE- MOUNTED OVER RANGE/WO
Amana MVH150E MWAVE - FAMILY SIZE (60 HZ)
Amana MVH150W MWAVE- MOUNTED OVER RANGE/WO
Amana MVH150W MWAVE - FAMILY SIZE (60 HZ)
 MVH1615WW Microwave Oven
 MVH1670ST Microwave Oven
Amana MVH200E MWAVE- MOUNTED OVER RANGE/WO
Amana MVH200E1 MWAVE- MOUNTED OVER RANGE/WO
Amana MVH200W1 MWAVE- MOUNTED OVER RANGE/WO
Amana MVH210E MWAVE- MOUNTED OVER RANGE/WO
Amana MVH210E1 MWAVE - FAMILY SIZE (60 HZ)
Amana MVH210W MWAVE- MOUNTED OVER RANGE/WO
Amana MVH210W1 MWAVE - FAMILY SIZE (60 HZ)
Amana MVH220E MWAVE- MOUNTED OVER RANGE/WO
Amana MVH220W MWAVE- MOUNTED OVER RANGE/WO
Amana MVH230E MWAVE- MOUNTED OVER RANGE/WO
Amana MVH230L MWAVE- MOUNTED OVER RANGE/WO
Amana MVH230W MWAVE- MOUNTED OVER RANGE/WO
Amana MVH240E MWAVE- MOUNTED OVER RANGE/WO
Amana MVH240L MWAVE- MOUNTED OVER RANGE/WO
Amana MVH240W MWAVE - FAMILY SIZE (60 HZ)
Amana MVH250C HOOD
Amana MVH250C MWAVE - FAMILY SIZE (60 HZ)
Amana MVH250E MWAVE - FAMILY SIZE (60 HZ)
Amana MVH250L MWAVE - FAMILY SIZE (60 HZ)
Amana MVH250W MWAVE - FAMILY SIZE (60 HZ)
Amana MVH320E MWAVE- MOUNTED OVER RANGE/WO
Amana MVH320L MWAVE- MOUNTED OVER RANGE/WO
Amana MVH320W MWAVE- MOUNTED OVER RANGE/WO
Amana MVH330E MWAVE - FAMILY SIZE (60 HZ)
Amana MVH330L MWAVE - FAMILY SIZE (60 HZ)
Amana MVH330W MWAVE - FAMILY SIZE (60 HZ)
Amana MVH340E MWAVE- MOUNTED OVER RANGE/WO
Amana MVH340L MWAVE - FAMILY SIZE (60 HZ)
Amana MVH340W MWAVE - FAMILY SIZE (60 HZ)
Amana MVH350C HOOD
Amana MVH350C MWAVE - FAMILY SIZE (60 HZ)
Amana MVH350E MWAVE - FAMILY SIZE (60 HZ)
Amana MVH350L MWAVE - FAMILY SIZE (60 HZ)
Amana MVH350SS MWAVE - FAMILY SIZE (60 HZ)
Amana MVH350W MWAVE - FAMILY SIZE (60 HZ)
Amana MVP211 MWAVE - FAMILY SIZE (60 HZ)
Maytag MVP5000TQ0 LAUNDRY TOWER
Maytag MVP8600TB0 LAUNDRY TOWER
Maytag MVP8600TU0 LAUNDRY TOWER
Maytag MVP8600TW0 LAUNDRY TOWER
Maytag MVP9000TB0 LAUNDRY TOWER
Maytag MVP9000TU0 LAUNDRY TOWER
Maytag MVP9000TW0 LAUNDRY TOWER
Maytag MVWB300WQ0 AUTOMATIC WASHER
Maytag MVWB300WQ1 AUTOMATIC WASHER
Maytag MVWB400VQ0 AUTOMATIC WASHER
Maytag MVWB450WQ0 AUTOMATIC WASHER
Maytag MVWB450WQ1 AUTOMATIC WASHER
Maytag MVWB700VQ0 AUTOMATIC WASHER
Maytag MVWB750WB0 AUTOMATIC WASHER
Maytag MVWB750WB1 AUTOMATIC WASHER
Maytag MVWB750WL0 AUTOMATIC WASHER
Maytag MVWB750WL1 AUTOMATIC WASHER
Maytag MVWB750WQ0 AUTOMATIC WASHER
Maytag MVWB750WQ1 AUTOMATIC WASHER
Maytag MVWB750WR0 AUTOMATIC WASHER
Maytag MVWB750WR1 AUTOMATIC WASHER
Maytag MVWB800VB0 AUTOMATIC WASHER
Maytag MVWB800VQ0 AUTOMATIC WASHER
Maytag MVWB800VU0 AUTOMATIC WASHER
Maytag MVWB850WB0 AUTOMATIC WASHER
Maytag MVWB850WB1 AUTOMATIC WASHER
Maytag MVWB850WL0 AUTOMATIC WASHER
Maytag MVWB850WL1 AUTOMATIC WASHER
Maytag MVWB850WQ0 AUTOMATIC WASHER
Maytag MVWB850WQ1 AUTOMATIC WASHER
Maytag MVWB850WR0 AUTOMATIC WASHER
Maytag MVWB850WR1 AUTOMATIC WASHER
Maytag MVWC300VW0 AUTOMATIC WASHER
Maytag MVWC300VW1 AUTOMATIC WASHER
Maytag MVWC400VW0 AUTOMATIC WASHER
Maytag MVWC400VW1 AUTOMATIC WASHER
Maytag MVWC450WW0 AUTOMATIC WASHER
Maytag MVWC500VW0 AUTOMATIC WASHER
Maytag MVWC500VW1 AUTOMATIC WASHER
Maytag MVWC5ESXW0 AUTOMATIC WASHER
  #2 (permalink)
Old 12-15-2014, 06:01 AM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
Please check your model number as no model matching it is coming up.
Then you can go to the parts page on this site and using that number you will be taken to an exploded view of your machine and you can see the timer or other parts that you will need.
Good luck.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Front Loading Washer doesn't work when Hot or Warm water selected. cdntrkr Washer Repair 0 09-14-2014 10:27 AM
no water flow into washer dbrashear Washer Repair 0 10-06-2010 10:01 AM
washer low cold water flow jtwestring Washer Repair 1 08-28-2009 07:08 AM
Water won't flow into washer gmarkert Washer Repair 1 11-30-2008 04:24 PM
washer wont run if cold water is selected dennchappy@netscape.net Washer Repair 2 04-09-2008 09:45 AM
