Need To Know Whythere Is An Excessive Water Leak Comming Out Of A Pre-made Hole In The Outer Drum Cover Next To The Drain Hose? Does The Floating Ball In Drain Hose Have Something To With That? Or What Could Cause That Particular Problem?
