| » washer does not drain the water |
Model Number: KAWE777BWH0 Brand: Kitchen Aid Age: 5 - 10 years
I use my washer with a electrical transformer (110v),because here in this country use a 220v. In the beginning was working properly,but one day i found the washer full of water
Please help me with this matter thank you so much!!!! Related Models |
What would happen if you turn the timer to spin?
__________________
Professional appliance repair in Orange County, California. |
Open the control panel and check the lid switch (#11 on the diagram). If it does fill with water and stops then the problem most likely is a bad lid switch.
If it does nothing at all and there is proper voltage to the washer then the problem most likely is a bad timer. - The lid switch Part number: AP3094500 - The timer Part number: AP2915897 Here are the breakdown diagrams and Control panel replacement parts for WHIRLPOOL KAWE777BWH0 | AppliancePartsPros.com Gene.
__________________
hi Gene!
I Send The Timer Control To Check Last Week And They Said Is Working Fine .definitely I Will Order Today The Lid Switch. I Hope This Resolve My Problem I Want To Ask You If The Washer Should Works Well With The Electrical Transformer, Because Some People Told Me ,all The Appliance (110v) With Cycles Did Not Work Properly When You Connect Them To A Transformer (220v).actually ,i Do Not Have Idea About That! ,but I Am Very Sure You Will Know It ! I Appreciate Your Help .thank You So Much,for Everything |
What is the transformer output voltage and amperage?
__________________
| Display Modes | |
| no spin, washer water won't drain | kabi54 | Washer Repair | 1 | 07-18-2009 08:25 AM |
| Washer Will Not Drain Water | coxcox2u | Washer Repair | 0 | 04-12-2009 12:29 PM |
| Washer does not drain water | kacody | Dishwasher Repair | 0 | 05-21-2008 02:00 PM |
| washer will not drain all water | john7500 | Washer Repair | 0 | 01-25-2008 06:27 PM |
| washer won't drain water out | groceryboy | Washer Repair | 1 | 12-24-2007 11:36 AM |
