I have a washer that will not start on wash cycle but if you advance to spin and drain it will. Change out the timer and lid switch and pressure switch. Dont know what els to check for need help. Thank you.
I am assuming it will not fill on any temp setting and will not fill for the wash cycle or the rinse cycle.
If so, and you have changed out the pressure switch and you know the water is on this suggests a problem with the water valve assembly. Try changing it out and see if that fixes things.
