I have a GE washer that won't enter the spin/drain cycle. It agitates fine, the magnetic lock/switch seems to be working. At the end of the was cycles it just stops. I do hear a very slight humming sound coming from it. Any tips or points to look at would be most helpful and greatly appreciated.
Thanks Rob
Never mind I figured it out. Pump was goggled up with with a bunch of nylon lint. Got lucky that it didn't burn out.
