Washer fills, but doesn't spin, agitate, drain or timer advance. No problems with lid switch or timer (purchased and replaced unnecessarily). Continuity tests on capacitor and motor OK. Might be problem in molex connector to motor. Saw a spark on white wire inside connector, burn spot on copper tab connector on motor side. Reset the pin as best I could without special tools. Washer filled, started to agitate. But, then burning smell so disconnected power. Several wires were warm running from connector to motor. Wiring harness side connector also warm near white and other wires. Can't determine if I'm actually seeing the source of the problem or something referred from someplace else. Looking for help from the experts. Thanks.
