washer will not dispense hot water. I checked the water line and it is fine. Switched the leads on the valves and the valve opens and dispenses hot water fine when the washer thinks it is dispensing cold water. Switched the selector knobs around and it is not the knob. Ordered the whole valve assembly on the advise of a parts distributor and that did not fix it. Any other ideas? System board is what I am thinking.
