Hello - yesterday water would not stop running into our Whirlpool washer. Even with unplugging the washer from the outlet, the water still would run into the machine, no matter what cycle, etc. The only way to get the water to stop was to turn off the main water supply coming into the machine. Should the water intake valve be replaced? Thanks!
