Recently replaced inner tub of whirlpool duet washer. Now tub does not spin due to motor not running. Door locks immediately upon plugging washer in. Can run diagnostics. goes through the cycles but no spin. Occasionally get f11 code. Tested motor with volt meter and tested ok. Harnesses all test ok. Probaby mcu but not sure. Is it normal to get electric shock from pulley when interlock switches for ground are depressed?
