I replaced the belt a couple of weeks ago. Washer just developed a unbearable squeal only at the very end of the spin cycle. I removed the front panel and the spin speed is very good. The squeal sounds like it is coming from the bottom of the tub, not the bearing. I let it run through the cycle to completion and the bearing housing was not even warm to the touch. This is why I was thinking the Trunnion. I have the machine apart now and it also looks like the tub seal is wearing. I will be replacing this as well.
Thanks for your help. Bobby
Replacing tub bearing and seal. Will post outcome.
